Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko wmb91142lw
- This topic has 12 replies, 6 voices, and was last updated 10 years, 6 months ago by
Andy jones.
September 25, 2015 at 2:16 pm #86198
Andy jones
ParticipantSn 12-402316-04. Prod. 7110841400
Hi guys
I fitted a pcb to this machine ( was damaged by a heavy handed teenager ) and all worked fine.
Customer just called to say all it does now is fill for a few seconds then drains. Keeps doing this and doesn’t move on to the main wash
Any ideas would be greatly appreciatedAndy
Sent from my iPad using Tapatalk HDSeptember 25, 2015 at 5:42 pm #430520simon26r
ParticipantRe: Beko wmb91142lw
Hi. Could just be motor carbons
September 25, 2015 at 6:30 pm #430521Andy jones
Will check them. Thanks simon
September 25, 2015 at 7:37 pm #430522geoff1
Sorry this motor does not have carbons.
If the unit is filling and them emptying it is more than likely the motor its self (board on motor faulty) another clue is the fact that the door is locked but the door locked symbol on display is not lit on display. would need to go into service mode to try and confirm.
Also check you have right module for the machine.Motor part number 2828010500
module part number 2431702082regards
Geoff
September 25, 2015 at 9:29 pm #430523Andy jones
Cheers Geoff. Will check
September 29, 2015 at 3:02 pm #430524Andy jones
Part no I fitted was 2827682081. Connect have done a pne check with Beko and they say it’s correct part.
Can anyone confirm
CheersSeptember 29, 2015 at 5:05 pm #430525Seamy
Change the diode, mounted below rear opening panel, usually sorts this problem out
2844290100
September 29, 2015 at 5:27 pm #430526Andy jones
Thanks seamy
September 29, 2015 at 5:31 pm #430527Andy jones
Could you check that part no seamy. Doesn’t show anything on connect. Many thanks
February 29, 2016 at 6:00 pm #430528Martin114
Did you sort this one Andy, only I have one with same fault and can’t find reference to a diode in the parts list.
Cheers,
Martin.February 29, 2016 at 8:59 pm #430529Lawrence
Its official name is INPUT IMPEDERENCE INDUCTOR GROUP
connect call it a transformer pt no 2889400300February 29, 2016 at 10:15 pm #430530Andy jones
I tried the transformer but no luck. Can only assume motor was faulty but customer decided to call it a day
February 29, 2016 at 10:43 pm #430531Martin114
Thanks for replies Lawrence and Andy. i think its motor as well but don’t think customer will proceed looking at costs.
Martin. -
