Beko WMB91242LB
  • #92182
    Jantech
    Morning all,
    I have a problem with the above machine, it gets stuck at around 16 mins left in the wash cycle.
    Heater is good, pressure switch is working, no blockages in pump and brushes are fine, I am stumped – any ideas?
    Many thanks
    Jim
    #450511
    Seamy
    Re: Beko WMB91242LB
    Should be starting rinse i’d imagine at that time, so maybe start by checking the water valve.
    #450512
    codlets
    Re: Beko WMB91242LB
    I had one same model same problem, test program quickly revealed it was the inlet valve
