Beko WMB91243 Washer Module
  • #91711
    folleyball
    The speed control has gone on this washing machine.
    It just ramps into full speed from nothing on wash or spin.
    The motor looks fine.
    Which module do I need to try. The main control module or the the Smaller DC module?
    #449028
    kaibart
    Re: Beko WMB91243 Washer Module
    Check the dc module if tracks are blown then that will need changing
    #449029
    Seamy
    If tracks were blown on DC module you would have no motor action.
    Main board would normally be at fault for the problem described, the tacho coil on motor needs to be checked also just in case.
