Had cause to visit the above machine. Stuck on spin with display showing 20 mins to run. It appears to be stuck on an 18 second loop. Pump runs for 18 seconds, pause, repeat. No signs of life from the motor. It doesn’t count down and it won’t cancel. I’m assuming that there is a logic fault on the PCB – unless anyone can advise me differently?
Have a Beko wmb91442lr doing the same fault as above , stuck on spin showing 20 but wont countdown or clear .
Is this a motor fault ? have checked the wiring in motor plug connections which appear to be ok .
