Beko wmb91442L
  • #91544
    pikotrain
    Fills with water but dies after 1 min. no motor/drum movement whatsoever, is there anything i can check before looking at the motor controller board?
    #448509
    Seamy
    Re: Beko wmb91442L
    Check solenoid coil of inlet valve, possibly its open circuit on one of the two coils.
    #448510
    kaibart
    Re: Beko wmb91442L
    I would be looking at a motor fault not cheap thou
    #448511
    Seamy
    Re: Beko wmb91442L
    If you are sure its motor related, i’d start by replacing the inductor first its the cheapest bit of motor circuit, but its difficult to diagnose without being able to test the product, the 3 phase motor can be tested by a meter to check the circuit is ok or not.
    #448512
    pikotrain
    Re: Beko wmb91442L
    Thanks chaps motor ok controller fault identified…
    #448513
    Gazz57
    Re: Beko wmb91442L
    How do you diagnose a controller fault? I have a similar problem with a beko, turns on and fill up then complete electricity loss at the point it should start to turn the drum and heat the water. Works ok on a cold wash though, changed the element but that hasn’t made any difference so now I’m thinking the control board.
    Any help would be very much appreciated!
