I was at one of these machines yesterday. It displays 25 minutes and all it does is drain for a few minutes, stops, the door lock light flickers then it repeats. I can’t cancel the program. There are no errors displayed.
I’ve had the board out and there is no obvious sign of overheating. The power board on the 3 phase motor also looks fine. Despite having it in bits when switched back on it goes back to 25 mins and starts pumping.
The machine is on a dairy farm and used for washing stuff you probably don’t want to know about. It’s in a cold damp shed with slurry everywhere, so there was only so much kneeling on the ground I was willing to do.
If anyone has had a similar problem I’d appreciate any advice.
Grant
