HELP!!!! this one wouldnt change programme just kept filling and empting with the door lock and E symbol going on and off, you are unable to change programmes. I replaced the PCB facia and selector as it was broken( multi pin connector snapped) so fitted new one. The programmes changed no problem but when I pushed the knob on I thought I had damaged it as you could no longer select a programme. I then ordered another one thinking I busted it to find as soon as you select a programme it stays in the display wont change and water in and out as the first issue. So it doesnt appear to be the PCB but have now neuked 2 of them. Thanks for reading
Cheers Johnnyboy
