The w/m will only continue to drain and is locked on one program. I can reset by holding start button and switching on. Then i can change the programs. But then it reverts back to original fault..Diagnostic check showed a F07 error then when I tried to check again it showed 04 17 on display. Anyone had this problem?
Hi F07 is the first fault found.
Which then would have been reset. The 04 17 is the software version on the board. I would also go for the motor or the wires on the motor….
Hth
Sparkyp
