Beko WMD 26145 T does not start spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WMD 26145 T does not start spinning
  • #88431
    Haramo
    Dear
    After starting the washmachine, water start filling. Everything fine I would say, but once enough wahter is filled , machine doesn’t do anything , like it i’s waiting for the next command.
    Lights are on , so not a electric problem.
    I hope it’s possible to fix.
    #438077
    Re: Beko WMD 26145 T does not start spinning
    Normally you’d get a fault code but if it fills then stops, heater is the first thing to look at.
    Haramo
    I don’t have a display that can show a code or how to see the fault code?
    heater, is that the part at the back side, just by opening the back side?
    Does it need to be replaced or cleaned?
    #438079
    normally, if there’s no display, the lit lights are a fault code and often they will flash to indicate a problem.
    The heater is buried at the back of the tub unit, bottom, just above the motor and if it’s open circuit it will need replaced.
    Haramo
    Gived it a try to check the led lights, they don’t flash, so will have to open it to check the warming element. I hope it’s the back side I have to open to find it, as the front side is very difficult to open as I tried it.
    #438081
    Haramo
    I found the heating eleemnt, disconected the cables, can I check without taking the heating element completely out?
    #438082
    Haramo
    ok, heating ohm is 26,3 Ohm, so ok
    the temperature senso, can I just get it out using force on that white connector? or can it break?
    see image:
    #438083
    Haramo
    thanks for the clear explaning video’s 🙂
    I managed to test the sensor: 4,4 K ohm, when holding it in my arms, the value dropped. I tested it again: 3,8 K , holding and value dropped.
    So seems ok for the heating element.
    What is next to test?
    #438084
    Motor I’d expect.
    Haramo
    Problem sovled, machine is back in action :-).
    I replaced the carbon brushes and this helped.
    Thanks for everything (this forum and the videos).
