Beko WMD78144 Washing Machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WMD78144 Washing Machine
  • #80242
    Sarahmc34
    Beko WMD78144 washing machine – will work with no washing in. But if you put some washing in the drum it doesnt work – if you select a cycle , it starts. But then the timer counts down to 18 minutes then goes back to 20 and keeps repeating this. Help please?
    #412211
    Seamy
    Re: Beko WMD78144 Washing Machine
    How old is the said appliance. possible loose belt, brushes worn etc.
    #412212
    Sarahmc34
    thank you for your reply – and apologies for my late reply back. appliance is about 2 year old – maybe 2 & 1/2 , Have checked brushes but motor is a one of the newer no brushes. , belt seems to look ok and works with no washing in the machine, but as soon as some weight goes into the washer it just stops
    #412213
    Seamy
    Think you would have to suspect a dodgy motor if its unable to turn the drum loaded. Asuming the appliance has the correct supply to it & the connections have been checked etc.
