i have the above mentioned washing machine. When it enters spin cycle and 2-3 minutes remaining, it jumps back to 29 minutes or if i put on spin drain program which is 20 minutes, goes down to 17 minutes then the drum stops and jumps back to 20 minutes, after couple mins goes to end.I have replaced DC board and control board so far but the error remaining the same. Any ideas?
Seems its detecting an unbalanced load and it is probable going back to start of spin cycle, check motor tacho for damage, cable to tacho, loom to motor etc.
