BEKO WME 8227w drum not spinning, no error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BEKO WME 8227w drum not spinning, no error code
Viewing 1 post (of 1 total)
  • #85727
    Hi there,
    my 4-y.o. BEKO just stopped working. It went through 2/3 of the washing cycle then froze at 53 minutes. There’s no error code. It fills, drains and heats water but the drum won’t revolve. It’s not overloaded BUT 2 washing cycles ago I did accidentally overload it. The only thing I’ve done so far is cleaned the filter.
    My question is:
    – is it something that can be easily repaired?
    – if not, is it worth calling an engineer or am I better off buying a new machine?
    – how much might the engineer charge?
    TIA
    UPD: just tried cancelling programme again then unplugged and left for a bit. Plugged in again, set on spinning cycle. The drum did move 1/4 turn then stopped
