Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko WME7227 WME8227 Laundry Range Carbon/Motor Failure
- This topic has 11 replies, 6 voices, and was last updated 14 years, 1 month ago by
TeeMyob.
March 5, 2012 at 1:38 pm #68265
TeeMyob
ParticipantHello,
Can Anyone help me shed some light on these machines for me please?
I have had 2 WME7227’s and one WME8227 Fail due to Worn Carbons.
When I have replaced the obviously worn carbons, the motor has failed to operate.
So I have replaced the motors. Everything seems okay to start with, then after a few washes, the motors fail to turn.
I have replaced the Main Modules but still having problems.
Is this a known issue?
Any ideas greatly welcomed.
TM
March 5, 2012 at 2:05 pm #370382Martin
ParticipantRe: Beko WME7227 WME8227 Laundry Range Carbon/Motor Failure
Broken wire in Motor Connector plug/wiring harness?
March 5, 2012 at 9:55 pm #370383TeeMyob
Going back to one in the morning.
Will see what I can find.
Spoke with the customer today and she said it sounds like it is trying (but that could be the pump running!).
Thanks for the reply.
TM
March 5, 2012 at 10:13 pm #370384leavemetogetonwithit
TeeMyob wrote:
I have had 2 WME7227’s and one WME8227 Fail due to Worn Carbons.TM
Give us a bit of context. Do you see a lot of these models and normally find that brush changes do the trick or are these the only examples you’ve come across?
If they’re the only ones you’ve seen, thanks for the warning, I’ll put them on my “caution” list!Mike.
March 5, 2012 at 10:45 pm #370385jimca007
I agree with Martin, the split stator motor on these ( used in the 12-1400 rpm variants ) are very prone to broken wires both on the loom side of the motor plug and the motor side don’t know if its due to the excess vib they all seem to suffer from but broken motor loom wires are regular. Unfortunately I work it a predominately deprived area and see a lot of these cheap junk, beko’s economy inde’s etc
March 5, 2012 at 11:09 pm #370386leavemetogetonwithit
jimca007 wrote:Unfortunately I work it a predominately deprived area and see a lot of these cheap junk, beko’s economy inde’s etc
There’s some down here that dream of owning one o’ them 🙁 .
Mike.March 6, 2012 at 2:05 am #370387jimca007
don’t get me wrong, financially these are my bread and butter it’d just be nice now and again not to have to clean my feet on the way out !
March 6, 2012 at 9:50 am #370388TeeMyob
Thanks folks
I have one on today and one tomorrow
I will let you know!
TM
March 7, 2012 at 8:57 am #370389TeeMyob
1st One.
Wrong motor supplied by CDSL.
And I did not check for any differences. Even if I had seen a different part number, I would have assumed it was a supersession or modified / supplemented part.
2nd One……
On for today.
Off to Sunny High Peak!
TM
March 7, 2012 at 1:46 pm #370390leavemetogetonwithit
?? This has still not been explained. Also why would the wrong motor work OK for a few washes?
Good luck and please keep us informed, it’s interesting!
Mike.November 27, 2012 at 10:23 am #370391DDSDDS
would love a update to this as got the same fault machine brushes are ok it appears to pump but no motor action
November 27, 2012 at 3:50 pm #370392gandh1
got a wme7267 in the workshop gathjering dust that was only 18 months old back last year, with same sort of issues – replaced module pump and wiring loom with no luck, and looks like maybe motor ?
