BEKO WME7247S Washing machine fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BEKO WME7247S Washing machine fault
  • #76313
    mjw1208
    Can anybody suggest where fault may be on this Beko wme7247 machine, fault is as follows cant change display /programme settings display only shows up 00 18 and flashing fourth symbol (spin?)in lower panel of five symbols ,when you select delay timer this goes up in 30 minutes ok but will go down to 01.00 then 00.30 then 00.18 etc , trying to change programme does have no effect whatsoever ,is the 00.18 some sort of error code any help appreciated thanks
    #398024
    Re: BEKO WME7247S Washing machine fault
    have got tech info if you want need an email
