Beko WME7267W help
  • #73375
    Sarahmc34
    My Beko WME7267W , turns on but the motor seems to “stutter” and wont do anything. Have checked pump and replaced motor but still seems to be doing to same thing. Any advice? Thanks
    #387266
    Seamy
    Re: Beko WME7267W help
    Motor replaced? Do you mean the drive motor or the pump motor?
    #387267
    Sarahmc34
    WE replaced the main motor , and checked the pump motor and pump motor worked.
    #387268
    Then it’s either a connection fault between the motor and the control module OR the control module is duff! 🙁
    #387269
    Sarahmc34
    Great cheers, was hopeing it would of been a cheap fix 🙁 guess not
    #387270
    Seamy
    I’d be trying a DC module, part num’ 2817690101, less that £20, before control board
