Beko WME8227S Washing M/C Fault
Home Forums Public Support Forums General Enquiries And Questions Beko WME8227S Washing M/C Fault
  • #72943
    Ovencleanman
    Hi All, need help please. Starting few weeks ago, cycled started to take a lot longer to complete. On quick wash cycle did not spin. Now the machine does nothing. When you press START I get the following on the digital display ” C on”. Then it goes back to the normal display. I have followed some of the advice in other forums but nothing has worked.
    Many thanks for any help in advance
    Tony
    #386028
    AJC_Dave
    Re: Beko WME8227S Washing M/C Fault
    Its the child lock. Look under the display, there is a line indicating two buttons to hold down to turn off the child lock. Hold them down until it displays c off or C on is removed. Sometimes have to turn the machine off and back on again to get it to work.
    Ovencleanman
    Thanks AJC Dave, it is now working. I doubt that will have solved the longer cycle issue and non spinning but at least it works.
    Thanks once again 😀
    #386030
    AJC_Dave
    Check its draining properly. Ensure the waste connection if its under the sink is clean is a good place to look. This could also be the cause of your spinning issue….
