beko wme8227w
  • #80080
    scottieshez
    Hi for some reason the drawer containing the fabric softener does not empty during the wash cycle and the softener is left in the drawer. i have tried taking the drawer out and rinsing it off and inside where the drawer goes but that hasnt worked. Any ideas?
    #411615
    ruralrecluse
    Re: beko wme8227w
    Make sure the conditioner reservoir is completely clean, including the cover which has a hollow tube, check that’s not blocked.
    Click on the link and that should explain all you need to know
    http://www.ukwhitegoods.co.uk/help/clea … awers.html
    #411616
    scottieshez
    Re: beko wme8227w
    Hi, thanks for the reply but I had already tried that and was so sure that must be the reason that I took the whole drawer out, scrubbed it and scrubbed inside the drawer space with a toothbrush but this hasnt worked. The drawer fills up with water but after the cycle it is empty except the softeher portion which is full of softener mixed with water. I use a detergent that goes in the drum but am wondering if I should put some in the drawer just to see if its still there after the cycle is complete.
