Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko WME8227W tripping RCD on pressing power button
- This topic has 7 replies, 3 voices, and was last updated 8 years, 7 months ago by
boazki.
August 26, 2017 at 5:51 pm #92010
boazki
ParticipantHi , washing machine has just tripped RCD on pressing the on button ANY help will be appreciated THANKS ! ( looked under machine , all dry , brushes changed 6 month ago and 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of original length , completed one wash this morning without issue). 😕
August 27, 2017 at 2:17 pm #449999Seamy
ParticipantRe: Beko WME8227W tripping RCD on pressing power button
Most likely heater, but could be anything
August 27, 2017 at 4:21 pm #4500001totalshambles
Just a pointer.
Last time I worked on this Beko WME series the dc module had blown. The dc module is the smaller module under the lid on the r/h/side of the machine. Same symptoms as yourself, switch on bang or trip if rcd. That was traced to the motor as the culprit shorting out and then taking out this pcboard. This is just a pointer only with luck it might just be a duff heater. Take wires off heater isolate them then try machine again. If it all goes to pot then check dc pcboard. If it looks like the board has blown tracks be careful you don`t get caught out lashing out on the parts as you might find that the main pcb is nuked too as well as the dc board as well as the motor. Sorry to be so pessimistic!
August 27, 2017 at 7:18 pm #450001boazki
5 washes a week @ 7 years & on 2nd set of motor brushes – otherwise looks and working like new (first machine with welded tub & i was worried about that LOL) not bad for £220 … will have a look as i like to FIX anything … BUT may get the same again… THANKS !!!
August 27, 2017 at 7:33 pm #4500021totalshambles
Agreed. Very good value for 220 quid. Yes, if you have a look, disconnect the heater and try at least you might be able to cancel out the heater as the culprit. Next try disconnecting the motor and the the terminal block off the dc pcboard although the way they wire these machines might prove not too much.
August 30, 2017 at 9:58 am #450003boazki
1totalshambles THANKS – motor is fried as well as the rest of it.. ( testing with the heater disconnected has broke the rcd & i had to fit a new one !!) new machine on way. 8) :fire:
September 3, 2017 at 2:30 pm #4500041totalshambles
All the best with your new machine.
September 3, 2017 at 4:18 pm #450005boazki
THANKS, already working hard… :))
