beko WMI71641
  • #91744
    suedehead1
    hi
    beko wmi71641 when put to spin it fills and empties at the same time
    obviously suspect pcb anyone know the part no,
    thanks.
    #449114
    Re: beko WMI71641
    well it coming up as part number 2427807031
    but things are never simple as there was a running change of these boards and I got the wrong one 3 months ago
    see attached sheet
    also if you set a normal programme does it over fill ?
    suedehead1
    Re: beko WMI71641
    never tried it on fill I have had problems with beko boards before also
    thanks
    #449116
    Re: beko WMI71641
    what I am trying to get at is could it be a shorted triac on the board controlling the valve. if yes its fixable
    suedehead1
    Re: beko WMI71641
    ok thanks , I will take a closer look thanks
