beko wmi71641 not pumping out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries beko wmi71641 not pumping out
  • #80067
    Redframz
    Beko wmi 71641 will fill but not emptying, cleared blockage, pump not working replaced pump still not working, megged heater ok, megged motor failed, striped and cleaned motor now its passing insulation test but still no pump action suspect main module.
    Don’t know how to get the test cycle on.
    Anyone got a service manual?
    #411553
    Seamy
    Re: beko wmi71641 not pumping out
    You can easilly make up a test lead, a cable with plug at one end & two crimped on amp tag connectors (insulated) suitable to push onto pump. Run pump on test carefully to prove its not sticking in housing for instance. Likely the triac that drives the pump has gone on the board because the pump overheated at some stage. Best news is the parts are cheap.
    #411554
    Redframz
    Hi Seamy thanks for getting back to me, I brought the wiring out through the filter hole and conncted it to the pump to check it still wouldn’t kick in, ran out of time as the customer was going out so when I go back to it on monday will do continuity checks on the wiring.
    do you know how to get it into test mode?
    #411555
    ruralrecluse
    Redframz wrote:Beko wmi 71641 will fill but not emptying, cleared blockage, pump not working replaced pump still not working, megged heater ok, megged motor failed, striped and cleaned motor now its passing insulation test but still no pump action suspect main module.
    TEST MODE
    Ensure door is closed
    Switch off appliance using on/off button
    Select COTTON program
    Whilst pressing START/PAUSE/CANCEL button, switch machine back on, keeping START/PAUSE/CANCEL depressed for a further 5 seconds and release.
    When in service mode the START/PAUSE/CANCEL button light will flash.
    Each time the START/PAUSE/CANCEL button is pressed it will advance the service program to the next stage as follows
    1 all symbols flashing
    2 motor rotates clockwise
    3 motor rotates counterclockwise
    4 spin to half of max speed
    5 pre-wash inlet fill
    6 main-wash inlet fill
    7 conditioner inlet fill
    8 heater on but only if correct water level reached
    9 hot water inlet if applicable
    10 end of cycle
    11 switch off appliance to exit test mode
    #411556
    Redframz
    Hi Ruralrecluse, thanks for the info
