Re: Beko WMi81341 Spin issues
Could be worth a look at the air trap chamber. look for the pressure switch, the thing that controls the water level, follow its thin hose down and you`ll find the air trap. It might be part blocked. If so the machine would over fill but not necessarily enough to cause a flood / error code, the air on pump out does not escape even though the machine has pumped out = the machine still thinks it has water in it = no spin.
