Beko wmp652w blowing RCD and making clicking noise
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko wmp652w blowing RCD and making clicking noise
  • #96479
    Sillypepper
    Hi All,
    got above washing machine, about 7 years old. Motor area makes a clicking noise that gets faster or slower depending on motor speed. Will complete a cycle without a spin cycle however any spin speed will cause the electrics to trip out once it starts to speed up. I’ve also noticed that the LCD starts to flicker at the point of tripping.
    does anyone have any ideas as to what this may be. So far drain pump and heater have tested fine as wash successfully completed.
    thanks
    Andrew
    #463535
    Main motor is shot, a section of the commutator has become raised causing the noise and tripping.
    #463536
    Sillypepper
    Awesome, would it be a motor swap job or could I get away with changing the brushes ( very novice with motors!!)
    #463537
    New brushes will not cure a commutator fault, new motor is the only option. 🙁
    #463538
    Sillypepper
    Haha, worth a shot, looks like new motor at the weekend then
