BEKO WMP652W SPINS ON WASH
  • #75058
    winker
    Have checked tacho coil circuit to main pcb ok,magnet ok and get a voltage if motor is spun.The fault is motor spins on wash and distribute speeds.I assume the main pcb needs repair or replacement but cant find a replacement part no.The other thing that puzzles me is the dc module,what does it do.any help appreciated
    #393724
    Re: BEKO WMP652W SPINS ON WASH
    does it work ok at wash speeds ?
    check you get tacho pulses to the pcb
    can get tech info but may take me a few days as i am quite busy
    let me have your email will see what i can do
