For want of a better description.
Customer says it’s an intermittent fault sometimes it sticks on the programme others it works ok.
On testing, even when cancelling the programme the machine starts and works for around ten seconds draining and with the jetwash pump spraying, stops for 20/30 seconds and then repeats.
On a wash programme the machine fills then does the stop start thing with the jetwash pump energised but with the motor juddering.
Checked the parts listing and found 3 boards :rolls: so I’m discounting the display (or is that tempting fate) for now. Is it purely a plug and hope with the other two, or is it a common fault….please 😉
Tony
