Beko WMXD760W will not do anything
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WMXD760W will not do anything
  • #63897
    Bernie
    I can select any program push the start button and that is it, the door has locked
    It did once when on spin prog start to turn and pump was running but when it stopped to reverse nothing,
    I can cancel the program and select another one but nothing.
    Has this machine got an electronic door lock as it will not open now stays locked.
    Bernie
    #355353
    Criscold
    Re: Beko WMXD760W will not do anything
    It sounds like the door lock, looking at the parts list it looks like the standard one. If you need diagnostics let me have your email.
    Colin
    #355354
    Bernie
    Thanks for the reply Colin, I will give it a try
    Bernie
    #355355
    Bernie
    Fitted new lock all worked fine only door handle broken now!
    Thanks once again Colin
    Bernie
