Hi all, this relatively new machine seems to leak from around the soap draw. I’ve only really noticed it happening right at the beginning of the cycle but it could happen at other times, a small but significant dribble appear as the draw fills, it’s messing up the floor beneath.
I’ve taken the draw out and cleaned it thoroughly along with the recess it goes in, I’ve poured hot water down the draining bit and checked as far as I can that there isn’t any soap build up, I’ve even bought a new draw although the old one looked fine, this seems to have improved it a bit but there is still water coming out. I’ve adjusted the water pressure on the water outlet although I’m going to try to do this again because I can’t see what else it can be. It would seem strange for it to be the water pressure thought as it didn’t do it when we first got it!
Can anyone think of anything else it might be?
Many thanks.
