Beko WTB941R4W Serice Manual
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WTB941R4W Serice Manual
  • #101263
    matrixresonator
    Don’t suppose anyone has service manual or knows how to access test cycle on this one, suspect faulty main PCB but thought I’d run test cycle before ordering.
    Customer originally reported it wasn’t completing cycles, everything tested OK other than heater was dead so I’ve replaced that.
    Got called back today and machine is stopping with 18 minutes left.
    Fills and drains OK, and if you select rinse and spin it completes that.
    Left it running on a cotton wash for 10/15 mins and no power goes to heater so im guessing heater relay on board.
    #484086
    sorted
    check your email
    matrixresonator
    electrofix wrote:sorted
    check your email
    Legend, thanks.
    #484088
    matrixresonator
    Quick update on this one.
    Put it into diagnostic mode and the last recorded error was E08 (full)
    On step 8 of the test cycle the main wash valve opens and fills.
    On step 9 nothing (should be softener valve)
    Swapped the connectors and on step 9 it now fills so looks like a dead softener valve.
    #484089
    Galway
    Any chance I could get test procedure access for this too please?
    #484090
    Galway wrote:Any chance I could get test procedure access for this too please?
    sorted
    Galway
    electrofix wrote:
    sorted
    Thanks a million
    #484092
    Galway
    After running test it comes up with E08 which is water intake error. Only getting 155 v to solenoid. Don’t see any broken cable or bad connections so, I presume it is something gone on module. Thanks
    #484093
    matrixresonator
    Check voltage with the connectors disconnected from the valve, I got some funny readings when connected to the faulty valve.
    #484094
    Galway
    Will do,
    thanks
