Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko WTK72042W (7137241700) Washing Machine “Dead.”
- This topic has 14 replies, 3 voices, and was last updated 2 years, 1 month ago by
jontymox.
March 5, 2024 at 6:25 pm #102625
jontymox
ParticipantGood evening all,
I’m wondering if anyone can help with a fault on the above w/m?
Essentially, the machine will not power up.
Several weeks ago I ordered the suspect board from Beko, which was on back order, and unavailable anywhere…
I suspected the board, as power is getting to it, and confirmed that the main power connections (two grey wires) are receiving a good voltage from the suppressor to the board.
However, the board arrived recently, and I fitted it today… to find the fault remains…
I’ve tried disconnecting the heater, and motor connections, as I’ve had problems with such causing the above fault in the past.
Not sure where to concentrate/test next, and would appreciate any assistance.
Regards,jonty
March 5, 2024 at 7:16 pm #489698electrofix
Moderatorok first off
do you know for certain board is correctif no
let me have serial no and the part no you fitted
March 5, 2024 at 8:52 pm #489699jontymox
ParticipantGood evening Dave,
The other serial number is: 21-108131-12
Part number: 2851545790 which I think is correct, looked the same, and fitted okay…
jontyMarch 5, 2024 at 9:21 pm #489700electrofix
Moderatorwell board is correct from my research
cant see any faults listed on tech site
its got to be something simple
if you have the old board try powering it up off the machine. its a single board so i cant see why it should not light up if its not faulty
you could have a new faulty board but proving that could be a problem. if it was me i would power the board and check for low voltage DC after the power chip
March 8, 2024 at 1:30 pm #489701jontymox
ParticipantThanks Dave,
I’m stumped with this fault…
I’ve tried powering up the old board, which doesn’t light up, and I cannot conclusively say whether the voltage is low after the power chip.
I may have to try another board, although the replacement to many weeks to arrive from Beko…
jontyMarch 8, 2024 at 6:27 pm #489702electrofix
Moderatorok post or send me good pictures of both sides of the main circuit board
March 10, 2024 at 3:57 pm #489703jontymox
ParticipantSorry Dave,
I’m struggling to upload/attach any photos from my camera at the moment…
There’s little of note on the original board – the machine is only just over two years old, with light use, and the board looks virtually brand new.
jontyMarch 10, 2024 at 4:21 pm #489704electrofix
Moderatorbut something must have made it stop working and components can fail at any time
what i am hoping is i can identify power supply components so you can test them
March 10, 2024 at 7:45 pm #489705jontymox
ParticipantThanks again Dave,
I’ll have further attempts in forwarding board images.
jontyMarch 10, 2024 at 8:10 pm #489706jontymox
ParticipantAgreed, there must be an underlying fault somewhere…
Hopefully images attached via a different arrangement.
March 10, 2024 at 8:58 pm #489707electrofix
Moderatorok
ORANGE check this resistor its normally about 47 ohms or so but well under 100
RED there are a numner of Shotky diodes on the output. had a few go short circuit and cause power supplies to fail. very common fault in Beko washer dryer. if you think its short unsolder one leg to be certain as can somtimes give false readings in circuit
YELLOW look very carefully at this chip. is there a blemish on the packaging that looks like it may have failed. it can often be very small round full stop size shiny bit
DaveMarch 11, 2024 at 6:38 pm #489708jontymox
ParticipantGood evening,
Thanks for your help Dave.
I’ve just tested the above.
The orange arrowed resistor gives an Ohms reading of: 98.5 Ohms
The red arrowed diode gives a reading of: 1.95KOhms
The microchip appears to be perfect.
So, wondering if the orange arrowed resistor is faulty, and what it relates to?
Thanks again,jonty
March 11, 2024 at 7:00 pm #489709electrofix
Moderatorthe orange resistor act as a current limiter on switch on and a fuse if something fails
100 ohm means its fine
red diode should have different readings if you reverse your leads. most meters have a diode test setting
look for similar diodes and measure them as well. cant see that end of the board properly so can give more info
if all ok you can try some live tests if you want to
look at the 3 capacitors and look at the voltage ratings. one will have 400v which should read 300v or so when energised
the other 2 will prob be low voltage poss 12 v or 5 V
all the voltages have to be there for the board to function
March 13, 2024 at 2:50 pm #489710baron
Participantjontymox wrote:
I suspected the board, as power is getting to it, and confirmed that the main power connections (two grey wires) are receiving a good voltage from the suppressor to the board.However, the board arrived recently, and I fitted it today… to find the fault remains…
jonty
Lets try again,
So I understand that even the new board is giving the same problem: “Does not light up“
From this point, you have to connect on the bench without any peripherals (one different power cable on the back of selector) and give a step rotation to selector (select any position of him apart ON/OFF).
Board should light up with an error….
I have doubt that new module has the same defect…Adrian
March 15, 2024 at 2:54 pm #489711jontymox
ParticipantI’ve finally had time and found the reason the original board isn’t powering up.
The contacts in the main selector switch are burned out.
However, not on the replacement board, which I’ve damaged to inspect. (switch housing)
My customer decided to purchase a new machine, so I’ll probably have to admit defeat on this one.
I suspect a short circuit from the heater, or motor for example, may be the underlying cause, and has immediately damaged something in the new board when fitted…
jonty -
