Beko WTL104121W washing machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WTL104121W washing machine
  • #100852
    dunston
    Anyone had this fault:
    The door interlock clicks randomly when the door is open. Doesn’t do it all the time.
    Or the door will lock and not open unless you use the mechanical release lever.
    When I called out the washing machine worked perfectly.
    #482398
    nothing i can think of apart from the board
    kaibart
    There was a tech bulletin about the heater ntc causing door lock problems on some Beko washers might be worth checking that
    #482400
    kaibart wrote:There was a tech bulletin about the heater ntc causing door lock problems on some Beko washers might be worth checking that
    well spotted not seen that one
    dunston
    Thanks. I’ll check the NTC
    #482402
    dunston
    Replaced NTC. It worked. Thanks again.
