Bel kensington 90df satinstl 444447037 – main heater element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bel kensington 90df satinstl 444447037 – main heater element
  • #102038
    piersandrews
    Hi gang, first time member who has seemingly exhausted all options but I thought i’d ask the experts if they had any ideas. My Kensington ovens lower element is bust, which has sent my wife stir crazy. After much time, I have worked out what element and got to Bel the manufacture to see if they had it in stock. Of all the parts, this is the one item that is obsolete. is this the end of the road for my oven, or is there hope.?…
    #487320
    well am getting obsolete as well but there is one light at the end of the tunnel
    gen element part no 082971800
    element rated 1000W at 230V
    should be this one if i read you post correctly
    https://elementman.co.uk/products/belling-082971800-genuine-base-oven-element
    Contact
    Homepage – TP Fay
    they make elements. had a few made by them as i dont live to far away but am sure they may be able to help. they will need the old element as they will need to reuse the bracket.
    piersandrews
    Dave, that is fantastic and i simply can not thank you enough. Now I have to get the element out, or should I get an engineer to do it?
    #487322
    piersandrews
    But then I worry it says like the other sites, its not available .. Do you recon I should ask him
    #487323
    fay make elements. they take a stock element which is straight and bend it to match the one they want. its facinating to watch as i have done a few times
    the only thing that may stop it is the low wattage but if you dont ask you dont get
    i would carefully remove the element. its probalby going to be in poor condition but try to preserve the shape as much as possible. you can show them the link i posted so they can see spec etc . make sure the wires are never going to touch anything while the element is out
