Belling 100dft
  • #99771
    rolf
    I’ve got a Belling 100DFT 444444053.
    I’m being lazy I know I should just go and look but
    Is there an easy way to get to the roller catch on this. It’s in the middle of the two ovens.
    Thanks.
    #477842
    rolf
    Went out and had a look can’t see anyway to get to the roller catch it’s between the two ovens. Can anyone please help or offer any advice.
    Thanks.
    #477843
    hebegebe
    I’m not familiar with the oven unit in question, but I use nylon cord a lot to position and hold awkward items whilst I get the first screw in. Drop it down from the top (under the hob) or pull it up from the underneath with string through the hole. A bit fiddly but if there’s a clear path for the old one to drop out then the replacement can be pulled in the the same way. Need to be sure there’s a clear path before dropping old one into the bowels of the oven though. Graham
    #477844
    rolf
    Thanks Graham. I really appreciate your advice. I did have a quick look on top but it was all covered and no obvious way underneath. I also started to take the front off but couldn’t see how to get behind it. I was going to take the back off and see if there was any space between the cavity and use a magnet to position but I ran out of time. When I go back at least I have another way of attack with the cord, Many thanks.
    #477845
    hebegebe wrote:I’m not familiar with the oven unit in question, but I use nylon cord a lot to position and hold awkward items whilst I get the first screw in. Drop it down from the top (under the hob) or pull it up from the underneath with string through the hole. A bit fiddly but if there’s a clear path for the old one to drop out then the replacement can be pulled in the the same way. Need to be sure there’s a clear path before dropping old one into the bowels of the oven though. Graham
    was thinking the same sort of thing
    either dropping it down or pulling it up. you may need something to compress the insulation in a bit to make room
    otherwise to have to completely dismantle the whole oven does not seem cost effective not to mention very bad design
