belling 205wh ring not heating to max temp
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries belling 205wh ring not heating to max temp
  • #75623
    slyp98
    hi guys i changed 2 of the large solid hob plates on this cooker , customer sayes it worked for a little while but now it wont bring water to a boil ,i have checked all the connections and power etc 😮
    #395677
    Re: belling 205wh ring not heating to max temp
    not mush to go wrong with these so its got to be 1 of the elements failed or the switch that controls it
    disconnect ring and check both elements
    also had one the other week where all the numbers were cleaned off and the customer was switching it to 1 instead of 6
    slyp98
    true dat , i will go back armed with switch and new element cheers
