Good afternoon,
I have replaced a faulty grill switch regulator as the grill wasn’t working.
It now switches on and off correctly, but the temperature cannot be controlled, and is permanently on maximum.
The part fitted was an alternative Hotpoint/Indesit item (C00225672) and required a straightforward wiring connection change as per enclosed instructions: Original Line to P1, Neutral to P2 and Load A to T2
Perhaps, a further wiring mod’ is needed, or should I be looking at other possible causes?
jonty
Pe
