Can someone clarify the part number or the 600x cooling fan (serial No: B300986).
A direct search for this part on Connects website returns Electrolux version 5031682000137 and Candy version 5031683156857. Using the Connections mediator the candy version isn’t listed and it doesn’t list as an alternative. Will the Candy version (5031683156857) fit this appliance.
I have put in a PNE on connections they say I should use a Stoves STV082603929 which is considerably more expensive than the other two options.
The other thing that complicates the issue is the motor listed are all left hand mounted motors where the one fitted is R/H Mounted.
Which should I use?
