Belling 6060 slow reaching temp.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Belling 6060 slow reaching temp.
  • #46634
    simtoms
    Old beast but still works wellish. Belling 6060 with double fan oven (both fan), both ovens work but seem to take about 45 mins to reach temp. I thought we could tell people that fan ovens almost did away with preheating…
    Fans work, elements provide heat, stats cut out and regulate fine once they’ve reached temp. Any suggestions as to why it takes so long to heat (and how to fix it) ? Thanks.
    #290276
    philfish
    Re: Belling 6060 slow reaching temp.
    fans are weak not getting up to speed or slowing down once they have been on a bit,element down or half the element working.
    #290277
    bzz67
    when you say it takes 45 mins to reach temp, does the pilot light not go out during this time. if the pilot is going on and off but the temp is too low then i would recon on slow fan speed. other wise i have seen only part of element working as philfish said.
    #290278
    simtoms
    thanks for that gents. Pilot staying on for 45 mins. Will try element first. Strange that both fan ovens are behaving like this.
