Belling 6061
  • #43068
    rickard
    Iam looking for the halogen ring for this cooker it is the front right one and the only halogen one. I cant find it listed anywhere
    Many Thanks
    #275912
    Re: Belling 6061
    Seems it may be obsolete. Could probably find a pattern equivalent if you know size. Or you could e-mail this chap, ttp://elementman.com/products.asp?cat=185
    Mike.
    #275913
    aqualectric
    Re: Belling 6061
    The halogen tubes in the original have been obsolete for some time now. ELE7052 from Connect is a halogen element unit 200mm in diameter and 1800W. The “look” is different when hot – not the 2 lamps across the plate but a halogen “loop” instead. It should fit that cooker with no particular modification apart from re-routing the wiring. Priced at £29.85 + VAT – not too bad. 😉
    HTH,
    Steve.
    #275914
    rickard
    Re: Belling 6061
    thanks for your help guys. I will order one from connect and fit
