Belling 627w
  • #60891
    S1MON
    Looked at the free-standing oven for a friend, was working fine till we switched it off to replace the worktops in the kitchen.
    The oven has 240v feed but no display and no functions work
    Anyhow checked all connections and components, 240v at the terminal block, refitted incoming cable. Removed the hob and there was 240v at the chock block that feeds the hob.
    I managed to get the the neon to activate, and there was 240v at the clock. Clock itself looks ok, but unable to find a thermal fuse which i believe is located in the loom?
    obviously the clock is 100, so open to any thoughts, thanks
    #344053
    Re: Belling 627w
    Sorta sounds like it might be stuck in auto mode. But I’d think you’d have figured that. If it was defo wkg b4 you switched off y shd thermal fuse blow?
    Mike.
    #344054
    S1MON
    Re: Belling 627w
    The clock has no display at all but does not look like it has blown.
    #344055
    Re: Belling 627w
    short the clock out and see if it works
    S1MON
    Ok ill do that
