Good afternoon,
Wondering if anyone can help with a small wiring problem on the above cooker.
I am trying to renew the top oven thermostat ass’y.
However, the oven is old and the thermostat has been modified slightly.
My only problem relates to the wiring connections on the rear of the switch.
The original letters are identified as F, G, & H
A single blue wire is connected to F, a single black wire is connected to G and a single black wire is also connected to H#
However, the modified switch letters are A, B, & C, so I don’t know which wires to connect to which terminal.
There is no information supplied with the new genuine unit, and I have tried contacting Belling without success.
All the other wiring connections relate identically, except the rear three as noted above.
Best wishes,
jontymox
