When you switch the oven thermostat off the fan stops but the temperature light and element stay on.
The thermostat is a 3 terminal version which feeds the fan and element.
The 3 terminal version is nolonger available and a 2 terminal version is now supplied but you have to contact belling regarding the wiring conversion hence i have started here as its cheaper than ring there numbers.
