Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Belling 647 main oven stat wiring change
- This topic has 4 replies, 3 voices, and was last updated 17 years, 5 months ago by
grazzamongrel.
October 23, 2008 at 7:51 pm #40450
grazzamongrel
Participanti have a Belling 647ss and customer complains that main oven is overheating so i diagnosed faulty thermostat. On ordering new one and stripping appliance down i discovered that it only had 2 tags but one fitted to cooker had 3 tags. On calling belling themselves they tell me that i also need a switch pack now and if buying from them or Connect that a new wirng diagram is included but guess what ..it wasnt 🙁
so any help on how i should reconnect the new stat and switch pack up would be greatly appreciated. 😉
October 24, 2008 at 7:32 am #266360grazzamongrel
ParticipantRe: Belling 647 main oven stat wiring change
please any help is greatly aprreciated as i have hit a wall here 😥
October 25, 2008 at 6:36 pm #266361electrofix
ModeratorRe: Belling 647 main oven stat wiring change
not sure if the same as the one i had but i assume its a fan oven
3 wires on old stat
live wire
fan live feed
element live feedall they have done is seperate the fan feed on another switch link a live to this other switch and put your fan feed on it
you have to have a continous feed to the fan and the element goes through the stat when you think about it its very simple circuits
October 25, 2008 at 10:17 pm #266362grazzamongrel
thanks for the reply. i have to fit a switch pack infront of the new stat. the switch pack has 2 contactors and not having done one of these for a while would appreciate the new wiring layout put in the most simpliest terms possible cos my brain aint firing on all cylinders lately.
i understand what you are saying about the 3 wires on the existing stat being 1. live feed 2. feed to fan 3. feed to element.
so with the switch pack i have to put the fan feed to this and link a live from new stat to the opposite side to which i have connected the fan. does it matter which contactor? or do both make a circuit when the knob is turned to select a temperature?
thank you in advance
October 25, 2008 at 11:21 pm #266363Penguin45
The live has to feed the fan motor and the element, so feed to the switch unit, spur to the stat, neutral on the other contact and you should find that you have an uncle called Robert. Continuity check will reveal which feeds which in a few seconds,
