Belling built in double oven
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Belling built in double oven
  • #93492
    allan
    Hoping someone can help with this please, been out to belling model number (bi90efr) 444443724 s/n 60902859 the pop out control knobs have pushed back out or the fascia looks like their held in place by a plastic collar which has broken away, having real problems finding out what I need, Qualtex as sent me a line drawing but it’s nothing like this, I’ll try and put a couple of pics as attachments
    Thanks Allan
    #454527
    Re: Belling built in double oven
    the knob is held on because it pushes on to the shaft of the control unit
    has the knob that fell off got a small metal or plastic stub sticking out of it
    then you need the control switch
    allan
    No the Knobs ok, it’s the plastic ring the knob sits in, which would also fix into the fascia, the whole units are falling into the top of the oven.
    #454529
    its not unusual for the shaft of the switch (arrowed) to snap off and be stuck in the knob
    I cannot see the end of the shaft in either picture and I would expect to see the end in the front panel picture
    if unsure put a picture on of the back of the knob
    allan
    Nothing wrong with the knob or shaft, the whole unit, selector and knob has pushed back through the Bezel, Qualtex have just got back to again with a part number for a plastic bezel 083469300 special order but no picture so I’m hoping it’s right.
    #454531
    ask them to email parts breakdown to you so you can see where the part fits
    sounds like a cheap bezel if its snapped it most of the time I expect these to be a metal part
    can see more of what you mean now even the knob next to the one that’s off is out of line so its the whole control support bracket
    may help
    allan
    Yeah it’s real crap, you can see in the picture where the nobs are still in place the plastic bezel around the knob is breaking up!
