belling cookcenter
  • #25544
    bendaireboy
    Hi guy’s has anyone got a wiringdiagram for the belling 132 cookcenter,there is no s/n or p/n andbelling only have it as electric oven,but this has 4 electric ovens 2x small 2x large and gas burner’s x5,the fan oven and two small oven’s work but I can get no supply voltage to the traditional oven stat,Ican see no cavity stat for this part of appliance,any help would be good ta very much
    #206330
    lokring
    Re: belling cookcenter
    have a close look around the main terminal block i seem to recall a bad spade on it causing something on those lines………..
    #206331
    helo_75
    yup, just like theres a thermal link from the terminal block to the oven stat
    its a blue wire, u can identify it cos its got a red sheath and is clipped to the cavity
    #206332
    bendaireboy
    ta guy’s I will let you know how I get on mucho apprreciated
    #206333
    bendaireboy
    apparently the beko made one’s have link but not belling this is definatley belling made .have checked for thermal links and checked terminal block, block ok ,but belling say its the switch pack,which the stat fit’s into but thers isn’t one on this model just stat fitted directly to facia,the wiring diag shows switch pack aswell,is there another 132 wiring diag that someone may have or will I have to go back to first principles
