Re: Belling Cookcenter electric cooker (Model no. 130)
Yin wrote: Any ideas how to fix? Is it something I could repair/replace myself?
Most obvious things to check are (firstly) the element and (secondly) the element control rheostat. As to whether you are able then I will let you be the judge. You will need the correct tools and test equipment plus a good degree of electrical knowledge.
The alternative is to call in a local independent expert who most likely will fix it quickly and cheaply for you. 😀
