Belling cookcentre 112 DF
  • #25305
    Steven
    Cooling fan noisey, went to change it, rear panel cover exposes the fan, thought great 5 minute job but they have put screws on top to fix it which you cant get to without what looks like removing the hole top, theres not enough room for an angle screw driver.
    As it is gas hob can it be removed without disturbing gas? & if so how do you remove the hob top.
    Many thanks
    Steven
    #205297
    aqualectric
    Re: Belling cookcentre 112 DF
    Grey area if you are not Corgi registered. If you remove the hob, disturb nothing, but later a fault arises with the gas parts of the cooker, you could be in the proverbial. :hitfan:
    I know it’s a shame to pass up a job, but the general concensus on this forum is – Don’t risk it.
    Steve.
