Belling Cooker – Almost a fire – new Loom?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Belling Cooker – Almost a fire – new Loom?
  • #89296
    RocketMan
    FSE 60 DO/444449570
    https://1drv.ms/i/s!AkhS_gobKY2tiuAFMsoMYLkvdVWPmw
    Hopefully you can see the picture??
    Take a look at the state of this Belling Cooker (FSE 60 DO/444449570)
    The customer smelt burning but carried on cooking.
    Some of the the wires are too short and too damaged to cut back.
    Anyone know the part no of a new loom or shall I just replace the all the indivual wires to the connector block?
    I’ve done quite a few Belling connector blocks but this has to be the best/worst – depending on your view.
    #440943
    Re: Belling Cooker – Almost a fire – new Loom?
    More likely that the mains cable hasn’t been tightened enough. Butt connect the wiring with new wiring.Not a problem if you use the correct crimping pliers and I don’t mean those cheap chinese that buckle when ever theres pressure put on them.
    Bryan
    #440944
    RocketMan
    Thanks 🙂
