Belling cooling fan stuck
  • #91416
    slyp98
    Hi all, I checked this belling xou70fp mk 2; and the cooling fan mounted on the back panel won’t turn, checked the voltage that’s ok 228v , so as you do install new fan motor but no same problem the motor won’t run its getting power so I’m stuck here any help appreciated thanks
    #447992
    Re: Belling cooling fan stuck
    is there 240 volts across the terminals of the fan? i think not, you may have 2 lives but no neutral
    this fan is controlled by a pcb, chances are the power supply capacitor on the pcb has failed. Change that or the whole board and it should work
    slyp98
    Hi Dave , I have 220 across the tags alright a live and neutral, the neutral coming from that PCB mentioned, and the live coming from the main switch and through a temp cut out , I’m a bit puzzled all I can think is its not getting the amperage also the neutral from said PCB is always on , as soon as the oven is switched on its live , I would have expected at 80 degrees it strarts up cooling ?
    #447994
    slyp98 wrote: I would have expected at 80 degrees it strarts up cooling ?
    Ah! There be where the problem lies.
    #447995
    if its not getting the amperage then the voltage will go down on the fan. did you check the voltage under load ie leads connected to fan ?
    if you measure with leads off the fan you will not get an acurate reading as you meter is prob around a 1 meg ohm load
    slyp98
    I did a test with leads on and off fan Dave , I also took a neutral from the main connector box coming in , in all cases it read 220v on my meter I’m stumped here the only thing I didn’t do was take a fly lead to the fan , I will try that
    #447997
    let me get this right
    are you connecting your meter leads to both terminals on the fan motor
    or
    1 lead to the main neutral and getting 240v on both connections
    still think pcb power supply cap is most likely fault
    slyp98
    I’ve tested power at the fan motor terminals , 220 and with the wires off the fan motor 220v , then suspected a neutral fault so I ran wire fro the main incoming neutral to the fan motor terminal, with it’s own live and also read 220v , the fan motor is faintly buzzing and is getting warm , the neutral is coming from PCB so why then is it not working with an external neutral this is what I can’t understand
    #447999
    what’s the voltage with the wires on the fan motor
    if you measure with the wires off you will get a false reading
    slyp98
    It’s just over 228 v
    #448001
    in that case it must be a faulty fan as it should run on 228v
    as a last check get a plug and lead and power fan motor directly through a 3amp fuse for safety
    you can try it on the old fan first
    let me know what happens
