Belling DB90 Range Cooker
  • #30896
    johnnyhoz
    Hi all
    changed energy regulators on the above, one single and one dual, the single was no problem but the dual has been substituted at some time from a Invensys to an EGO, changed the connections all matched with the same numbered tags but there were two extra on the EGO S1 & 4a
    tested the ring but in each position of the regulator both sides of the ring heated up. Has anyone had this before or is there a connection diagram available somewhere ?
    John
    #228847
    Seamy
    Re: Belling DB90 Range Cooker
    I’ve actually got to go to one of these this week, do you know part numbers for simmerstats, both single & double please
    #228848
    johnnyhoz
    Hi Seamy,
    stats are 082611723 & 082612573
    but I still have problems with the conversion of the dual stat as my pevious post stated, no joy with a wiring diagram yet, the only diagram available is for Diamond H regulators none for EGO
    John
    #228849
    johnnyhoz
    Has anyone got the contact details for Belling / Stoves, do you think they will give me the wiring details regarding the Invensys change to EGO Stats ?
    John
    #228850
    SWERV
    Hi, did you manage to sort this one out? we’ve got one with exactly the same problem.
    Regards
    Mervin
    #228851
    DentedPorsche
    Hiya,
    Give the model number of the original and new regulators and the pin outs on them.
    I’ll work out the rewire for you.
    Brian 😀
