Belling DB900e Mains Block
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Belling DB900e Mains Block
  • #83953
    grooster
    We’ve been out to a Belling oven DB900e and the mains block (terminal block) has burnt away.
    I’ve looked everywhere for the part but nothing is coming up.
    Does anybody know a part number for this part or know of an alternative.
    Any help is really appreciated guys.
    #424334
    don
    Re: Belling DB900e Mains Block
    Part number according to Connect is 082612535.
    Searching on Connect for belling terminal block does bring up quite a few, so it may be worth you comparing yours with the pictures if you have a Connect account of course.
    Don
    #424335
    grooster
    Cheers Don, really appreciate your help mate.
    #424336
    Chris Blatch
    They are fairly generic, as long as it can take the total load of the appliance and as long as it fits safely, with no chance of coming away and has the correct number of terminals on the rear, it should be fine.
    As it’s a full electric range, the max load will be quite high.
    Any equivalent GDHA (Belling/Stoves) terminal block will suffice.
    If you can post a pic of the rear, I’ll have a look at some of my stock as I have lots of spare ones.
    #424337
    grooster
    Hi, Part no, 082612535 says its obsolete on Connect and Qualtex. From memory it looked like a double terminal block. Didn’t take a photo unfortunately and its not close enough to go and see it again.
    I’ll just have to look through a load of images for something that looks similar.
    Cheers
