Belling Duel Fuel oven prob
  • #40385
    OLLIE2806
    I have been to a duel fuel (stove type) Belling Platinum db3. ser: 03001164 which has probs with main electric oven, it works o.k untill its been used on a high heat for a while then cuts out. Cust says if left for 20 mins or so after it cuts out you can use it again but same prop occurs. The cust claims the last time it cut out she couldn’t get it to work for a few days. When i got there it worked first time everytime.
    I suspected there must be a cut out on involved but scrolling through the parts list i cant see, my only other though is maybe the contacts on the selector switch may go iffy when it heats up other then i’m a bit stuck.
    Any ideas would be greatly appreciated.
    Thanks in advance guys.
    Ollie.
    #265998
    helo_75
    theres a thermal fuse.. from the neutral on the terminal block to the selector
    if you take the back off, you can clearly see it, its on a metal hook, attatched to the cavity
    they do normally stay off when it goes though
    only protection it has, i believe
