Re: Belling DW problems
Most likely problem with the 603 is a pressure switch problem
If it isnt flashing up an “E” number in the display, then second most likely cause is the door catch is opening slightly, normally caused by poor installation allowing the cabinet to flex too much
If there is any water in the pressure switch hose, replace it. There is an unnoficial mod kit, aint no part number sorry, which basically lengthens the pressure switch hose so that you can loop it a little higher.
What “E” number is it flagging up??
